Moderators: Larry Jowdy, VintageGreg, vintage shop
Greenberg wrote:Still has to put on the front tube and some more cross bracing then off to powder coat. It looks like Greg is using thicker tubing than he was before on the cross bracing.
Greenberg wrote:Anyone with a vintage may be able to answer these questions. Just in front of the front hoop there is a mounting plate with 3 bolts only on the right side, what is this plate for. Secondly, on the rear there are 2 very thin tubes that go from the center of the cockpit to the sides of the frame and then continue back, what are these for.
Thanks.
Mark
tim johnson wrote:Yes, the plate with three holes is for a cross brace for a roll bar. The only problem with using this type of brace is, it eliminates the possibility of having a passenger. I had an additional/identical plate welded in on the left side and had the roll hoop braced twice, one left, one right. It allows for a passenger/coach for tracking purposes.
